hey guys,
in attempt to change over to a leather shift knob i started poking around today. here is how my shifter sits now, minus the knob. i believe its a b&m.
i want to install the black shiftknob thats sitting on the passenger seat. i could get it to all match up, but the new knob would be about 1" higher than the one thats on there now(below e-brake).. now this is how it looks with the aluminum assembly removed:
now my question is:
are the two areas highlighted in red threaded extensions??
the new knob only requires a rubber nipple on top of the rod, then it simply gets tightened down with some small pins.. if those are extensions i could simply remove the top one and button it all back up. i dont want to cut it because if i do i wont be able to tighten the old knob back on as it grabs the thread at the very top of the shifter rod.. anyone??:shrug:
now my question is:
