I did a drum to disk conversion in my 99 SE, took me about 6 hours.
Heres what you need:
- Brand new Parking brake cables for disc brakes
- both rear Disk brake hubs from any other Disc brake contour (95-00 non svt)
- Calipers and brackets from the same rear disc contour, you might be best off buying new calipers, just to be sure that the ones you get arent failing or leaking.
- obviously brand new rotors and pads
You will need to jimmy stuff around to get it all to fit properly, but replacing the hubs really isnt that hard of a task, its about 5 bolts to take the hub down, most of which are 15mm, the pinch bolt on the strut is a 17 or an 18 mm (GET A LONG BREAKER BAR!)
the only hard part to the rear disc conversion is getting the parking brake cables swapped, I ended up cutting mine and never installing them, but you need to drop the exhaust, and drop down the heat shield above the exhaust system where the parking brake cables lead to, there is one big fat cable (coming from the handle) and 2 smaller cables that branch off to your wheels on either side.
If you have any other questions, feel free to ask. But doing a Drum to disk conversion isnt as simple as taking off the drums and putting discs and calipers on.
I also will say, that the most cost effective way to do this; is making a junk yard run and getting most of the parts, otherwise it gets super costly, and almost isn't really worth it.
