hallfleming
So my rear toe arms are bent from being towed the wrong way by the PO. I removed the subframe for welding and forgot how the toe arms went on. Is the top edge flat or other way? This appears that the top edge is flat so the end would "bow" down on each arm from the picture below. Thanks!
http://www.contour.org/ceg-vb/showthread.php?59447-Project-Hip-Replacement&highlight=rear+arm
