Duh, totally forgot I have the Ford factory service program :blackeye: ...
REMOVAL AND INSTALLATION
Special Tool(s)
Expander, Teflon Seal, or equivalent
211 - D027 (D90P - 3517 - A)
Remover, Pulley, Power Steering Pump
211 - 016 (T69L - 10300 - B)
Installer, Pulley, Power Steering Pump
211 - 185 (T91P - 3A733 - A)
Removal
01. Disconnect the battery ground cable.
02. Raise and support the vehicle. For additional information, refer to Section 100-02 .
03. Remove the lower splash shield.
04. Remove the accessory drive belt. For additional information, refer to Section 303-05 .
05. Lower the vehicle.
06. Remove the accessory drive belt upper guard.
07. Detach the high - pressure tube support bracket.
08. Disconnect the power steering pump low - pressure hose.
-Drain the fluid into a suitable container.
09. Detach the coolant hose retaining bracket.
10. Using the special tool, remove the power steering pump pulley.
11. Disconnect the power steering pump high - pressure tube union.
12. Remove the power steering pump.
-Remove the four power steering pump retaining bolts.
Now I just need a puller and installer :help:
