It is the crossfire paint for that price. It is a value line/grade paint & be advised that you will not get as good of color coverage as if you were to step up a grade in paint, this will be especially evident when you are doing a color change. You may very well end up w/ several more coats than anticipated with this line & it's very doubtful that you can do a complete color change including all jambs & under the hood with one gallon. It took nearly a gallon to do my t-red & that was just the complete outside, the same color that it was.
What color is the car now?
edit: if it's the multi-color car in your cardomain page...I'd suggest priming it all out w/ a light color primer to ensure you'll wind up w/ even color.
