Myrosia
1999 Contour, 2.0, 4cyl, Zetec, Vin 3, 165.000 miles
There has been a leak in the rear main seal that started last fall. Very little and not much I was worried about.
I've always been running Motorcraft 5x20 semisynthetic oil along with Motorcraft FL-400-S.
2 weeks ago, I was suggested to use Castrol GTX High Mileage 5x30. So, I went along and had them change the oil.
The next few days I noticed and INCREASE in oil leak on my drive. Actually quite a lot. I looked at the underbelly and it's leaking the same place as last fall but more. Then I noticed that there was a Fram oil filter instead of the Motorcraft FL-400-S I always use.
Oh another thing, there is now some oil in the air filter cabinet.
Question:
1. is it a coincidence my leak is worst?
2. should I keep with the Castrol?
3. should I switch back to the Motorcraft filter?
Question:
