m4gician
Just want to know if there is a how-to or some brief instruction on how to remove the old air box, and mount the K&N filter + adapator to your system...
remove the PCM fuses.
Pulling the battery WILL work, but you also lose stored radio stations, clock settings, etc. If you don't mind, then pull it.
If you do, then pull the PCM fuses (11, and 9, or 11, and 6 (a 3A and a 20A) in the engine bay fuse box.
I've always pulled both, but now that I think about it, it's cause Ray told me how to reset it a few years ago by pulling both.:laugh: Since it worked, I never questioned it.
