Blackcoog
So I switched from 19lb injectors to 42lb injectors in my Cougar. I have the SFG1 SVT Contour ECU in my Cougar so as far as the ECU was concerned they were stock. I had a base tune sent to me from brenspeed which seemed to be pretty good. I swap over the injectors the other day and started going through the tune. I changed all the values in scalar section under fuel to the recommended values for 42lb injectors. I also changed the injector pulse width to the recommended value and the injector voltage values to the recommended values.
Car still runs way too rich (10.0). I can tune it in on my own but I should be able to change the software and get it to run exactly like it had 19's in there. I'm sure I'm either missing something or the recommended values in the software are incorrect. Any ideas?
Thanks,
Chris
Thanks,
Chris
