Slim57
When I was replacing sway bar bushings on 1995 GL w Duratec. Previously I'd noticed what seemed like excessive engine vibration under acceleration, or other different engine load situations.
Contact is very obvious after driver side front wheel is removed, and subframe is viewed looking straight into the wheel well opening.
Moving inward toward vehicle centerline, I see what looks like engine mount in front and rear of engine, inboard of the subframe.
Can anyone suggest which mount or mounts most likely need replacement?
Thank you.
Thank you.
