m4gician
Okay well I'll post pics in the morning, but here's how the basics of it go,
Obtain a Gentex or similar mirror with at least the Compass feature. (Those with temperature feature will be a little more complicated because of the fact you will need to install a sensor which will probably be inaccurate anyways and will not factor in wind chill and humidity.)
Here's a basic how-to
The mirror, depending on the one you get (got mine off a 2000 Crown Vic), will have a power harness wire attached to the mirror and that's it. Depending on which mirror it is again, that will determine what and how many wires are connected to that harness.
Step 1, make sure there is enough length of that harness as you'll need to strip the wiring and solder (or connect using electrical tape and some bending of the wires)
Step 2, if you have a sunroof, great because you're not going to have to try and run wires to the dash or ignition coil.
Step 3, remove sunroof panel and find the cable connecting to the sunroof motor (not the one connecting from the switch to the motor).
Step 4, strip a little of the wiring off each wire (one should be black, the other should have a purple and black combo or similar).
Step 5, Look at your mirror and locate the wires coming out of the FIRST and SECOND spots, if you have a gentex mirror, it'll be marked 1,2,3,4,5..etc. Wire #1 IS ALWAYS THE 12v connector, and having that connected to the sunroof wire will ensure that whenver the ignition is turned on the mirror is on. I originally had it wrapped around the dome light and it stayed on at a reduced output which wasn't good.
Step 6, do the same as step 5 for the black wire, and any black wire will do.
Step 7, mount the mirror onto your bracket and use either goop or a good long lasting TOUGH adhesive as it will benefit you in the end when your mirror doesn't shake.
Voila, done and done .
