DirtyBird
Ok, so I have been researching this a lot, and i think I have the majority of what needs to go down, but I'm still a little fuzzy on a couple things.
1) for some reason my 97 SE has the old pre 95 side style injectors, which im guessing wont matter, but still wierd. It also has the return fuel line system. from what i have gathered, the 3.0l is returnless. Can i still use my fuel lines/pump, and just plug the return side, and tune? Or do i have to replace the pump and everything?
2) i have the stock exhaust manifolds, a glass pack instead of the main cat, and the svt cat-back pipes and mufflers (sounds good!) If i was to gut the 'pre-cats' in the manifolds, and put the mileliminators in, will that effect, or make tuning (at a race shop) impossible? Not sure if the tune uses the O2 sensors to do it.
3) what are the advantages/disadvantages of doing a full 3.0 ( TB, UIM, LIM, valve covers etc) vs. Doing a hybrid (2.5 uim, lim, tb, valve covers etc)? Sounds like with the full 3.0 may be some sensor connectivity issues? And fuel line brazing? And the hybrid you have to port the heads? Anything else?
I know you guys are all prolly gonna say to search more, but i've been researching for months, and cant find details on doing a pre 98 3.0l swap. and i am on a budget for this project, about 3 grand, for the new engine, clutch, and remanufactured tranny, and tune. So I am tryin to anticipate all the ins and outs and possible snags.
Thanks for your help guys! You have already helped me a TON with other things ive done. Much appreciated!
