percybigun
just thought i'd post up pics of this brake upgrade which fits the mondeo (so should fit straight on your contours etc)
the caliper brackets off the focus, meant they bolted straight onto the mondeo hub. i had to drill the disks to be 4-stud though.
i'm not sure if the new Focus ST is available in USA? its the 2.5litre 5 cylinder turbo model. not to be confused with the old Focus SVT (which only had the 300mm front brakes)
anyway the FST brake kits normally go for around £150 GBP (for pads, disks, calipers & brackets) second hand on ebay UK.
the caliper is only single piston, and is the same size piston as the old Focus SVT but the caliper is much bigger. i had the SVT brakes before and they were good, but stopping power is much better with these. one of the pics shows the comparison in size between the FST caliper and the FSVT caliper.
