ford zetec2
can we remove the egr valves on pre98s or to will be a problem!!!
you have to have it turned off in a tune using either an xcal or a chip. once that is done you can remove the valve and install a blockoff plate.can we remove the egr valves on pre98s or to will be a problem!!!
nope, i have a broken tie-rodok thanks man.....are you ready for a race...
