azbobbybooshay10
You guys seem more performance-oriented over here so I will ask this here first. I just picked up an early 1999 Cougar V6 5-speed that the previous owner claims blew a head gasket. He started to have work done on the engine before the mechanic stopped messing with it. The top of the engine is apart (UIM missing, fuel injectors unplugged, miscellaneous other parts missing). I have a good 2.5 that I plan on swapping into the car to get this one running as it would be a perfect daily driver. My plan was then to take my black car that is gutted out and throw a 3L into it, but I got an idea last night.
What type of parts are out there to build a "built up" 2.5 using the engine that is partially apart? I picked up the whole car for $450, and would like to get as much "bang for the buck" possible, so if I can rebuild this 2.5 (assuming everything measures out ok and it is rebuildable) I would definitely like to do that. I've already found the good connecting rods and bearing kits on Nautilus Performance, but I only see 3L pistons, not 2.5. Does anyone out there make high compression 2.5 pistons? I want to get in touch with Buckeye about the cam work he does and see about doing some custom cams for it. I know the "easy" way to do it is obviously just tossing this 2.5 aside and doing a 3L, but if this 2.5 is rebuildable, I would like to make use of the resources and parts I already have sitting here.
