Brake pedal push rod disconnect
sprucehill
Be Gentle I'm New Here
98 ford Contour
How do you disconnect the clip for the Brake pedal push rod? I have crawled under the dash and I cannot see how to get the pin out that runs through the push rod and the brake pedal. It has a white plastic bushing with a split end that slides over the brake light push rod, and the ends of the pin are round thick steel with two flat sides.
Anyone? Thanks.
