Butterbean
- Joined
- May 8, 2013
- Messages
- 6
Bought a 99 Contour for my daughter to drive the other day. On the way home started noticing 1 to 2 gear bang, speedo bouncing at no motion, problems shifting through the gears. From going through all the forums and searching them, I concluded to purchase a new speed sensor to see if that would fix the problem.
Went out to replace the speed sensor in a 99 Contour 4 cylinder Zetec 2 liter. It was easy to get to but one heck of a time getting it all out of the hole of which it was in. It came apart in pieces. Ended up using a Dremel tool with a diamond drill to remove the last piece. Managed to get all the pieces of plastic out.
Now the problem, went to the parts store to get a new one and bore for the old sensor was about 11/16" bore. The new sensor has a bore size of almost 7/8" and will not even be close to being able to insert it back into trannie. Two parts stores said the new one I had was the correct one, but it wont fit the bore.http://www.contour.org/ceg-vb/images/smilies/ubb/crazy.gif
Anyone seen this one????
