99contourSE
The transmission has been scraping for quite some time now in 1st and 3rd gear. If i go easy on it, it doesn't scrape. I replaced the clutch(It had the original at 230,000miles) I know this because the car was my grandfather's and he was the only owner. Anyways, It didn't fix the problem and found it to be the synchros. The other night, driving home from work, I took a corner and lone behold, I had no second gear!!! I tried to downshift but it would only let me into fourth. The really weird part? I could physically slide the shifter over to where second gear should have been without the clutch being pressed in and without lifting it out of gear it just slid. After a couple minutes the shifter locked back into fouth and I was able to downshift to second again. Why is this? Has anyone ever run across a problem similar to this before? It's happened to me twice now, and it's really got me scratching my head. Any help is appreciated.
