SVTJON87
OK guys ever since i replaced my stock head unit the drivers speaker would cut in and out. put kappas in the car and had the same problem. so when i was installing the dash clock i looked over the harnesses ( stock and aftermarket) and realized pins were loose. took some super glue and glued the wires from the back. after testing it everything worked again. that same night i grabbed 2nd gear and then there was no sound from any speaker. i was like great i fixed one problem and caused another. so i have not gone back in there to look but something its obviously wrong with the speaker wire harness. can anyone give me some tips? i really think the problem is coming from the connections behind the head unit. thanks guys
