theSCHAFF
I want to remove the door ding guards and the 24v emblems. Whats the best way i can do so that is as painless as possible ? They're just stuck on w/ adhesives right ? no holes will be left behind afterwards ?
.There is a hole in the fender behind the 24v emblem.
Ouch. I didn't know my left side doors were repainted and it turned out like this.be careful with the door molding... see if there is a way that you can test what you got going on behind there... I pulled all moldings off, got to the very last one and a HUGE strip of paint came off because there was rust and moisture a brewin back there..
needed the entire door refinished.
I think many others here have experienced the same fate
that was my Drivers Side door.
Though it doesn't neccessarily look bad.
Big Picture: http://www.fototime.com/{5B4FBA73-0F5D-4F98-B13A-C94B17EBFA4B}/picture.JPG
I tried dental floss but if you don't have much patience like me, it won't get you very far :laugh: I peeled the guards off and then the aluminum stuff if that didn't come off with it. Then I put on a pair of thick heat resistent gloves and rubbed of the rubber while blow drying it. Not too hard :shrug:
