Ok you've got a lot of searching to do...In a nutshell...Buy a 2001+ Taurus/Sable motor. Either a) port the heads and swap over 2.5 intakes or b) keep the 3L intakes and fab up some vacuum lines and replace some stuff then drop it back in. Search the old forums. A lot of info there.
The SVT controller will not control the ATX. You need the one that came with the car that the trans is from and then you will need a tune to optimize the engine performance.
