I would only consider getting the SVT TB unless your going to get the SVT UIM (upper intake manifold) as well. By the way, if you get the SVT TB, you also need the new throttle linkage, bracket, TPS sensor, gasket, etc.
Would a SVT UIM, LIM & TB from a salvage yard, in good condition of course, be good enough?
What do you mean good enough? If you mean, do you need anything else, then yes, you need the SVT TB bracket, linkage, TPS, etc. Oh, and make sure you get a return LIM instead of a returnless.
im pretty sure you can just swap over your current fuel rail
