8000RPM
sometimes, in cold days, my car stops blowing out hot air when I come to a stop light. I strats blowing cool air, and then when I start driving again, the heat comes back on...why?
If you haven't changed the WP before, that would most probably be it.anyone with another suggestion????? or confirm that it's the waterpump?
The black plastic impeller is bad. The white plastic impeller (found in all 99-00 Contours and available at NAPA I think) is fine. Some people recommend the white plastic impeller over the metal one.Make sure when you do replace it, get the one with the metal impeallar, not the plastic one.
NAPA, just impeller.When you replace the water pump with a NAPA one, what exactly are you getting? the whole pump or just the impeller? if just the impeller, how do you install that?
Thanks,
Adam
