I'm getting ~26 mpg. Seems rather poor for a 4/MTX, I'll prob replace the plugs 1st. Is there any other quick/simple task that would give better milage?
One note is that the temp gauge needle barely gets out of the white block, never in the normal range. Could this be from a faulty sending unit?
Also, when idleing, the TACH sometimes cycles between 700-1100 RPM, won't hold steady.
The Check Engine Light was on when I bought it, (excessive lean code), replaced the air filter, disconnected the battery, and it hasn't come back on (~1000 miles ago).
Thanks
Thanks
