evilm0nk3y
- Joined
- Dec 13, 2006
- Messages
- 58
I have a contour gl 2.0 DOHC, recently Ive been losing almost a full resevoir of coolant every couple days. when i put the car on ramps, i could see the antifreeze dripping from it seemd to be around one of the pulleys on the serp belt. Would it to safe to assume that possibly my water pump has went bad? When I turn on my heat to max, hot air DOES come out so I dont think its failed completely, but just enough to start leaking. I read in a haynes manual that If i took off the timing covers theres a vent hole in the water pump and if thats leaking then the pumps definitely bad. Im assuming thats the only way to know for sure?
Second: My contour runs usually around the A or L in normal... Ive noticed that my radiator fan comes on intermittantly, How would i tell if my relays are bad? And would I just order two of the same relays for both low and high speed?
Thanks in advanced
Thanks in advanced
