maintenance
maintenance
Hi there, I just wanted to add that Big Jim is right about checking gap on your new plugs ALWAYS before installing. I have found them to be out gap range right out of the box, sometimes by as much as ten thousandths or more.
I also want to say that you won't need to remove the intake or coil pack to pull the rear bank plugs. It's a little tight back there, but manageable, I found it easiest for myself to use a good swivel with six inch extension and then a three inch ext. after that connected to the ratchet. Get some nickel antisieze to put on the threads before install also, this will help prevent the chance of the plugs bieng stuck in the head at your next routine change. P.S. DON'T FORGET TO INSTALL THE NEW PLUGS BY HAND FIRST, USE THE EXTENSION W/ NO RATCHET, UNTIL HAND TIGHT!
On another note, the oil pan bolt is a 15mm, the little screws that hold on the front valve cover shield is 1/4 inch or 7-8mm, good time to check your water pump area and the drive belt too. Don't hesitate to give us all a shout here if you have any other questions and good luck.
Jim
