Pale Horse
I have a severe alignment problem. Let me give you a little background on the vehicle. It is a 98 E0 with a '97 build date. It runs the 4-bolt control arms and subframe. A little over a year ago, I had a wreck in it (my first wreck ever). It was bad. I hit a concrete retaining wall somewhere in the 100MPH area. I hit the wall at an angle that crushed the front end in from the passenger side ( probably around a 45 degree angle). The frame ended up having a slight buckle behind the passenger wheel. It sat in the frame shop for about 2 months before it was fixed. I had to take a front clip from a salvage car in order to allow the frame shop to pull the frame. They had to weld from just in front of the shock tower forward. The work looks very professional, with good welds and all of my body panels lined up without problems when I started to put it back together. Everything seems fine as far as the frame shop's work is concerned. When I got the car running again it pulled hard to the right. I went through the suspension and replaced everything that even looked questionable. I replaced the control arms, ball joints, tie rod ends, right side knuckle, and wheel bearing with hub. The shocks looked fine upon examination as well as the springs. At this point I had it aligned. The guy said there was no way he could get it aligned and that all he could do is compensate for tire wear. I said "ok, i'll do some more research." Upon further exam. I end up replacing the drivers side ball joint and passenger axle. Then I took back to the alignment shop and had them align it again. This time it is pulling really hard to the left. It can make a left turn just by giving it gas.
I am at a slight loss as to what is causing this. The only things that I can think of is a misaligned subframe (which didn't get bent in the accident but perhaps it got skewed from the impact) or a problem with the LSD. The impact took the passenger side wheel off but left the hub of the wheel attached to the knuckle...yikes! So perhaps I could have damaged the LSD somehow. I don't know guys. I am just at a loss as to why this is still a problem. Is there any kind of adjustment that can be done to the subframe? It's been a long time since I have had the motor out of the car. I can't remeber if there is any way to do this.
Thanks in advance guys and gals!
