Okay.. I feel awkward EVER posting anything troubleshooting related. very.
Here is my question.
Can anyone fill me in on the state and role of the PATS module and associated wiring (etc) once the car is actually running? I understand the ability of the module to prevent starting, but once started does it still continually check for the correct key? For example: If I were to saw off the black fob on the end of the key while running, and remove it from the ignition vacinity, would the car die?
If not, can anyone fill me in on what the PATS status LED SHOULD be doing while running (off at all times while running, right??) what about a list of PATS status flashes, and meaning? (codes, "all good" flash counts, anything!)
Starting just today, I am getting a very serious BUCK/SURGE (imagine cruising at 10 or 15 mph in neutral, then placing car in first and DUMPING the clutch out. that "grabbing hard and surging" feeling is what I am experiencing. usually sparse, and not affected by load, gear, rpm, or speed (the surge/buck is as violent at 60mph as it is at 30) Sometimes the Tachometer needle will fall instantly (like you shut the car off) by about 500 or 800 rpm, but the engine tone is not dropping..
The reason I ask about PATS is that the instant it does this, the pats LED illuminates and remains for about 1 second (steady) then goes off. If, per chance, the bucking is closer together, then the PATS light flickers, then the last one is steady (as if its doing it once per "bucking") Is this a failing PATS?
No problems starting car... no problems idling. nothing! Just.. bucking. I looked at the plugs and wires, and all is copacetic. If it was spark, I would think it would be more violent at high load/low rpm, or at LEAST able to be affected with driving style!
VSS affect running condition of the car? I think not.
Fuel? full tank and newer pump!
spark? nice plugs and new(er) wires
air/vacuum condition would seemingly cause more precise and localized (by speed/rpm, or at ALL times, even idle)
What say the collective brains of CEG. Those that can help, thank you. those that can not.. listen up so that you can help the next guy with this problem!
