95 zetec, 5spd, 216k, drop in K&N.
seeming a random occurance, only when the engine is cold. some mornings its worse then others too. Normally on level ground at light throttle and pretty much steady engine rpm I will get a bad bucking/hesitation. Once up to temp it doesn't seem to be an issue. Also a few time getting on the highway in the morning and flooring it to get up to speed I have had it fall flat on its face around 5 k rpm. fuel level doesn't seem to effect anything.
in the last year I have changed the plugs and wires w/new motorcraft parts. Gota new O2 sensor and swapped to a coil with half the miles. The fuel filter isn't to old either. I do want to try cleaning the maf again to see if that makes a difference.
