LED question
pipedsvt
Ohio
Will these LED's work in my dash and also in my HVAC panel? I'm asking because the oem 194's have one prong one each side whereas these ones in the picture have 2 prongs on each side. Will these work ok?
WLED-xHP5 Wedge Base Bulb
Miniature Wedge Base Bulb(194/168 type) with 5 High Power SMD LEDs
12 VDC, 360 Viewing Angle, Polarized bulb
Select LED color
a 194 style bulb will work in the HVAC and headlight switch, although simply replacing the 2 bulbs in the HVAC with LEDs is not enough to light up the HVAC properly. a 194 DOES NOT work for the gauge cluster, the bulbs needed are smaller. search for a thread titled "interior help", the posts by myself should have all the info you need for the bulb types for the gauge cluster.
The HVAC takes a lot more work to actually look good.
