greasemonkey1489
I have been noticing my passenger side floorpan getting wet after a rain. I can't figure out where the water is coming from. Has anyone had this issue?
BINGO. My girls cougar leaks because her mount for her CAF is broke.if its by the front where the passenger's feet would go, it could very well be your cabin air filter, which might be bad. I had a small puddle of water in that area and changed out my cabin air filter,(it was NASTY), and put a new one in. Never has a leak again.
How do you change that filter? I never even touched mine in 10+ years
My car leaks from the same area and I figured out what it was long time ago but couldn't fix it. Mine was coming from A/C system. I stopped using A/C and floor dried up in a few days. At the time I went to a shop and they asked $400 labor to fix it because they said the whole dashboard needs to be removed. I said bye and it's been like that since then. When I need to use A/C, I use some shop towel to catch the water that builds up there. Been doing this for years. If I was in Arizona, I wouldn't need to do anything probably but in FL, humidity is everywhere...
FAQHow do you change that filter? I never even touched mine in 10+ years
