CSVT1214
Addicted CEG'er
1995 Mystique Zetec ATX 117k miles
Yesterday my brother called me and told me his car broke down. One of the coolant hoses burst and he lost all the coolant. I'm not sure how long it went without coolant before the engine decided to give up.
He got it towed home. I tried to crank it in the driveway but it didn't want to start. Today after work, I cranked it over and it started up with a little hesitation but ran very smooth after the idle settled. I tried it multiple times and no problems starting each time.
We went to AutoZone, picked up the replacement hose. I threw it on, filled up the coolant tank and tried to fire it up again. No start now. Cranks and cranks but doesn't start up.
With the overflow tank cap off, when cranking, "smoke" comes out. If I put my nose to it, the "smoke" appears to be gas fumes. The smell is pretty strong. The tank also bubbles while cranking and immediately after.
My guess is the head is cracked and it only fired up before because there was no coolant to interfere with the gas. Now with coolant flowing, it's mixing and can't fire.
Thoughts? New engine for sure? Head only? Tests to be done?
