My daughter is doing some preventative maintenance on her 1996 Mystique LS with the 2.5L V-6 and 187k miles on it. It runs good but has an occasional hard shift with normal driving. She wants to change out the fluid to freshen it up.
What do you think about power flushing it? I have read about problems with this but have also read that most have no trouble with this method.
What about disconnecting a cooling line from the radiator and pumping it till clear and clean while adding new fluid to keep it from running dry?
I have read of the normal method of the three time drain and fill. Thanks for your replies!
