Not to be the perpetual sceptic, but is there not a physics law that directly correlates temp to pressure, meaning that little turbo can work as hard as it wants but the only factor on temp it the increase in pressure.
I guess, what im saying is temp and pressure should vary directly, turbo size should not play a factor in intake air temp.
Yeah you are forgetting friction. Air friction can generate a lot of heat.
Then there is the speed of the air as it approaches the speed of sound it does funny stuff...I'm no physicist.
The biggest T28 is only going to support 30#/min of air on a good day.
So 11psi is about 1.75 pressure ratio. Follow the compressor map to see what will happen
The T28 big 60:
-115K rpm at 1.75PR
-25#/min of air max before the air stalls out.
-efficiency drops to below 65% at that point
Efficiency is based upon how hot the air coming out of the turbo is due to compression, friction. The cooler the air out at a given pressure ratio, the more efficient. A bigger turbo is more efficient at moving more air at the same boost pressure. So cooler denser air coming out means a lot more power. Also the air is not moving as fast.
Volume and pressure can only be evaluated at equivalent temps. Obviously that is the major difference in the power.
Also, the T28 only made in the 290s HP on the 2.5L and it makes about the same on a 3L....makes sense because that is the max air it can flow.
Better to run lower boost pressure if you can and just increase the operational rpm range to make more power.
