piperpilotduane
- Joined
- Dec 16, 2008
- Messages
- 40
I have a svt contour with variable assist power steering. The upper pressure hose leaking at the pump fitting. Someone had already cut and put a flare fitting right above the rubber hose and I am not sure the section from the fitting to the P/S pump is correct. looks like it was bent down to clear the hood and has still rubbed the hood liner. Can anyone upload or send me a pic of the topside of the engine bay showing the hose around the pass. motor mount? I cut off the nut at the end and scarred the surface the o-ring will hit and cannot use the one that was on it. (I DO NOT WANT TO DROP SUBFRAME TO PUT NEW HOSE IN). If I have to buy a new hose, Who has the best price? I hate to pay $60 to cut it off at the rubber hose.
