Over the last couple of days, my 98 SE (110k) has developed a runaway RPM problem. In short, it periodically wants to throttle up on its own. Here's what I've observed so far:
- It doesn't consistently occur. During any given duration of driving, it happens roughly 70% of the time.
- It only appears to occur after the engine has operated at highway speeds/RPMs for a while. For instance, at neighborhood speeds/RPMs, it hasn't occured.
- When it's apparent the engine is doing a runaway, I'll pop it into neutral to observe how far it'll go. It climbs steadily to between 3.5k and 4k RPM (never higher). Usually, in less than 10 seconds, it will drop off to idle RPM. When a runaway occurs, it always follows this pattern.
- Although it normally recovers from the runaway in less than 10 seconds, sometimes it's longer. A handful have lasted beyond 20 seconds.
- I can't tell precisely when a runaway starts, because I'm driving at a high RPM to begin with. Only when I want to coast or brake to a slower speed does it become apparent the engine wants to maintain the higher RPM. It's like trying to brake with your foot still on the accelerator.
My gut tells me this is a sensor issue of some sort. Can someone help narrow this down? I'm hoping it's a simple part swap...
