Frosty
I finally got my SVT back on the road a couple weeks ago after putting in my 3L and I have a couple issues. Here is the story:
Dropped in ported 3.0 with 3.0 cams/timing, headers and mil eliminators (Tuned) and got it back on the road 8/2008 with no issues and about 24 hours later I proceeded to destroy the diff by accident. Sat until April when I got a built trans, dropped the subframe and replaced the busted trans. Drove it that night a little and parked it so I could go get it registered the next day (it was due for emissions inspection) and get it aligned. No CEL, no sign of trouble. Next day I start it up and it idles up and down and finally settles in around 1750rpm and runs like crap and suddenly has a CEL. P0171 and P0174 and sounds like I have a Vac. leak. The gaskets were changed when I ported the 3L and I used the bugzuki plate with RTV gasket maker or whatever its called. I looked at the gaskets and they were a little wet and no longer had the blue on them so I got a new set and replaced them. Intakes looked pretty clean so I left them alone. Fired it back up and different codes this time (I didn't write them down). Took intakes apart again and inspected lower plate and it seems sealed all the way around. Put the gaskets back in and still runs rough, but hasn't thrown a CEL yet (prolly because I had the battery out and it hasn't completed a cycle yet). I will try to get the second set of codes as soon as I can, but anybody have any suggestions?? I'm not sure what else it could be. I replaced all the injectors when I did the 3L and there were no problems the first time I had it on the road. I have a temp registration and need to get it to pass emissions by the 28th of June. Any help is greatly appreciated.
