where do you get this information? the egr valve itself is normally never a problem. very few egr problems arise from the egr valve itself. they are very reliable on the contour.
again the P0402 points to the dpfe sensor.
cars I have fixed for people? :shrug: and my EGR valve failed once, and I have replaced 2 others on different cars which repaired both P0401 and P0402, however DPFE very well could also throw that same code. The fact that it isnt
normally a problem doesnt mean that it cant be a problem ever.
im not trying to be a jerk or anything, but aliasjerk, just stop posting advice like you do. you keep telling people to replace things, and fix things that they dont need. get your facts straight before telling people what to do. people will see how long you've been on here and how many posts you have, and take your advice. people should be learning how to fix their cars, not just taking random stabs at things, hoping that it fixes their CEL. you are like the stereotypical autozone employee. "oh, you have a catalytic converter code. replace your cat. ohhh heres an EGR code. replace your EGR valve" i just really dont like the way you post in here. yes, i know you're trying to help the members out here, but it bothers me the way you go at it. sorry, just speaking my mind
For one, this post is irrelevant in this thread if you have a personal problem with my posts then please feel free to contact me via private message, for 2, you didn't post or say any advice to rectify his issue what so ever, looking at the codes this kid posted its pretty obvious what the problems are. For 3 P0402 is related to the EGR system, there are 3 separate components it could be, 1 of which is extremely unlikely which is the EGR vacuum controller solenoid on the back of the Upper intake manifold. Another of which is the DPFE sensor which is considerably more likely although in my experience I have never actually
needed to change one, another of which is the EGR valve; which I have had to replace on upwards of 3 cars already to rectify a P0402 code. Am I saying "I am always right, every time" absolutely not, I am man enough to admit in the past I have suggested some stuff that I know better of after having more experience, but this is a simple issue which I have experienced and repaired in the past. Furthermore, you came out and suggested that his O2 sensor on bank 1 might not be functioning properly. So let me get this straight you are mad at me for suggesting 1 new O2 which we all know he needs on bank 2, thats a given, and an EGR valve and an $8 can of B-12, which costs a total of about $90. But you have no problems suggesting for him to spend another $50 on a 2nd O2 sensor which has a lower likely hood of being the problem, Nice. In what world does your solution cost less than mine?
However, it could also very well be a broken vacuum line behind the intake manifold on the EGR solenoid. When my friends and I dropped my SVT motor back into my car I kept getting all kinds of weird vacuum and EGR codes totally randomly, I replaced my EGR valve and my DPFE and the same codes kept on returning. Turned out that the damn vacuum tree fitting for the EGR solenoid had come off during the motor reinstall, slid the connector back on, and got a solid P0402, which turned out to be the (drum roll please) EGR VALVE!
Further more, I am far from an autozone employee and I suggested doing ???? that costs little to nothing to fix, running a can of Berryman's B-12 costs ????ing $8 for gods sake, and did fix my P0420 and P0430 codes which are indicative of the front and rear cats not working as efficiently as they should, not to mention it fixed the exact same issues with my friend's 97 SE contour. I didnt even need to touch my O2 sensors and as of a year later my car still hasn't thrown these codes again. How in the hell is suggesting an $8 can of seafoam bad advice?
If you have a problem with my advice, fine, take it to PM and I will thoroughly explain why I suggested what I suggested based upon personal experience, and/or what my Ford CD suggested as steps taken to diagnose issues. I am confused as towards what brought out this huge slanderous post, suggesting an EGR valve replacement when there is a possibility of someone needing a new EGR valve.
