Dyoel182
Addicted CEG'er
The alternator wiring may be the big actually. I was thinking about the other pitiful ground wires that could be beefed up.
I'm actually going to attempt to do the big 3 in the next 2 weeks (hopefully the next few days). I've replaced the alternator before, so I'm aware of the PITA it's gonna be. Anyway, when I do get around to it, I'll make sure to take a ton of high resolution pics and make a thread with detailed instructions on how I did it.
we also used a torch to solder the ends on...unless you have the right tool, it's next to impossible to properly crimp a connector on 0 gauge wire...
should even do it where bear wire enters a terminal with a set screw also.
yeah I need to go back and do that with all the connections for my relocated battery. should even do it where bear wire enters a terminal with a set screw also.
Baer?
Another reason I just bought the pre-made lawn/garden cables. I didnt want to break my crimper trying to crimp a connection poorly to begin with.
should even do it where bare wire enters a terminal with a set screw also.
how would you do this, would you tin the wire first and still put the "bare" wire in the terminal with set screw?
lol, two soldering irons...I almost missed that. Try using a butane torch for sweating pipes next time...only took a couple seconds as long as you regulate the flame so you don't melt the wire insulation too bad...you can also use a pair of pliers as a heat sink to keep the heat out of the rest of the wire...works great on that 0 gauge.
