SPATT
Need some help with a project at work. None of us have to know-how. Involves powering a LED backlight from a laptop.
well why dont you tell us exactly what it is you want to do.
Are you powering an LED backlight from a laptop screen or something?
Any idea what the old backlight was?
Battery voltage?
So the stock backlight was a power consumption 1.84W and the new backlight is 25.785W.
A good size laptop battery would be drained in probably less than 30-45 minutes with just the backlight alone.
2.7A is a fairly considerable amount to run through a printed Circuit Board of the density in a laptop I'd say. So finding a good point to tap in my be a challenge.
An a note that's more helpful/encouraging... there are many options to regulate from one voltage to another.
What's the intended purpose for this backlight? Why are you repacing it with something that's so much more power? Do you want to have the power circuitry inside the laptop case? Do you want a battery life longer than 20min?
2.7A is the battery output if I read it correctly, but I'm not local, so I could be wrong :laugh:
.You are wrong, so please go away, you're not helping.
