So my v6/ATX shifts fine when its cold, I can drive the car ~40 minutes on the highway before I get into traffic where I work.
Once into traffic (stop and go about 10 minutes) the trans wants to bang through all the gears.
I get to work. leave at the end of the day, drive through the slow traffic first, then drive all the way home, and no bang.
Is it possible that there is a sensor thats getting heat soaked and failing?
I had a friend with an interpid whos 4 speed electronically-smucking-fart trans would not shift when his 02 sensor one of the banks failed.
Can the Contour suffer the same fate? Mine's had one of the upstreams changed, and I have the "newer" replacement TSS inplace. Problems started a few thousand after the TSS was put in. The replaced o2 was in before well then.
Any Suggestions?
Any Suggestions?
