FavoriteMystaque
- Joined
- Oct 16, 2004
- Messages
- 1,192
Recently, I resurrected the audio system in my 1998 Mystique. I installed a stock CD Radio to the factory amp, then the stock speakers sounded rattly. I took out a stock speaker, figured out the spider had unglued from the magnet, and while looking at it, noticed it had an odd dome tweeter that was glued to a short horn. There was an ICT logo on the magnet label. I looked it up, found they were like the Tannoy speaker pictured below! InductivelyCoupledTweeter, and they do work!
I decided to carefully cut loose the outer edge of the rubber surround and reglued the spider. Tricky to reassemble without scraping noises. Played well, fixed two others and reinstalled, they may be good enough to use with better equipment later on. Sound is clear and "together", just a bit of door "boominess". Not bad..Anyone else ever encounter these speakers?
