ok I've got one for you guys. I just finished installing a 3l and it started fine but the BAT. light is on and steady. now I've checked the grounds and i'll double check them again. but I remember when I hooked up my knock sensor, I had to splice the wiring harness. I used bullit type plugs on the wires so I can switch it around if needed.
So, if I connected it wrong, do you think this would be the cause of my car not charging cause I may have connected positive to negative?
