teamSVTour
You like large women with no bumps? WTH is the point of that?
:laugh:
My vote is for 18's - busted ass stock suspension with ~140K in this pic.
Meh....18's start to look small. That's why I upgraded to 19's
My 19's weigh 48+ lbs with tires, and I noticed zero decrease in fuel mileage or acceleration. Then again, I do have a 3L with 210 WHP and 206 WTQ...
I love my 18" wheels but man, there are times I really wish I never ditched my 17"s.
And what did my FSVT's weigh? 43 or so?
My 18's with tires....18x7.5 rim with.....225/45/18 ====30lbs
What model rim and tire? That seems way too light.
Only 15 lbs for the wheel and 15 lbs for the tire? :shrug:
Hi, I am relatively new here. I do like all the free information given. Thanks. I have a question. I am thinking of buying some rims for my 99 SE Comtour. Will 18" rims fit with 225/40/18 tires? Will it raise or lower the car? Will they rub on turns? Any advice will be greatly appreceiated. Thanks again
225/40/18 is a widely used size for 18's on a contour/cougar. you should be fine at stock height but it will slightly raise the car and give you more wheel gap. slightly lowering it as mentioned above will make it look alot nicer. you may have to slightly roll the rear wheel well but it kinda depends on the shape of the sidewalls on the tires you get. i had a set that did and a set that didnt lolHi, I am relatively new here. I do like all the free information given. Thanks. I have a question. I am thinking of buying some rims for my 99 SE Comtour. Will 18" rims fit with 225/40/18 tires? Will it raise or lower the car? Will they rub on turns? Any advice will be greatly appreceiated. Thanks again
So you are the clowns that almost stop at every &%$&( dip in the road so you don't scrape on the ground or scrape your tires on the body work. We just love it when you do that, slows traffic down and generally pisses off the rest of us. But they do look cool.
dude I havent noticed your posts until very recently and from what I have seen you post................ most of the time i think you should prob STFU:shrug:So you are the clowns that almost stop at every &%$&( dip in the road so you don't scrape on the ground or scrape your tires on the body work. We just love it when you do that, slows traffic down and generally pisses off the rest of us. But they do look cool.
let me spell it out for you then you tool.I don't understand what STFU means, several of you crybabies have suggested that I do it, can any of you crybabies help me on this?
