Okay i was installing an upgraded lim on my svt. As soon as i started the car up, it rev'd to 1200 rpms. So aftering look around the engine bay...i started to tackle the vacume lines. Nothing was disconnected, I didn't even hear a hissing sound at all. So i thought i might double check the manifold gaskets again and retorqe them to spec.
So i remove the upper and put 100inch pounds to the screws on the lower. I then reinstall the UIM and connect everything else. Once i connect everything i went to start it and it rev'd to 3k rpms and then idle'd at 2.5k rpms.
For 3 days...i'm stuck!! I replaced all gaskets...uim/lim, egr,tb,iac gaskets.
I took the tps and IAC sensors off my running SE and put them on the svt...and yup problem is still there!!
So i'm ing stuck and i have no ing clue what could be left. Purdysvt stopped over one day and we pressure checked a few lines. We found one to be weezing. that was corrected today. Now i can't find anything that would be causing this!!
So i reinstalled my stock lim and well the problem is still there.
ANy ideas...clues?
ANy ideas...clues?
