Or you could try some low cost troubleshooting
If it is low pressure disabling the ac compressor clutch, you will need to look at the wiring diagram, find the low pressure switch, and bypass it with a wire. This assumes that the low pressure switch is normally open and closes with adequate pressure and is not an input to the car's computer. If your clutch works you know that either your switch is bad or your freon pressure is low. A piece of wire is one heck of alot cheaper than a set of gages you may not need.
If it is low pressure, it is a good idea to take it to a good tech who will determine the best course of action. Likely a leak check is in order.
