I downloaded the doc from the web site but now it is too large to repost??? I don't seem to be able to save the connector pic separately from the doc and it is to large by itself to post in the doc...... here are the rest of the instructions. If you want the whole thing PM me with your email add.
AF
The clock has only 8 pins on the back. From those 8 only 5 are used if you have PASSIVE ANTITHEFT, otherwise only 4 are used.
Looking at the connector:
PIN 3 (Violet) is 12 volt from the ignition(12 volt when key is turned).
PIN 4 (White/Red) is the voltage for Illumination (From Dimmer)
PIN 5 (Black/Orange) Ground
PIN 11 (Black/Orange) Comes from Antitheft (If available)
PIN 12 (Orange) 12 volts continuous (Memory)
Details.
If you already have Passive Antitheft on your car, then the cables that are used to the give power to the existing LED can be used for PINS 11,12. The ORANGE has 12 volts and can be put at PIN 12, while the other one (I think Black/Violet) can go to PIN 11.
The rest of the cables, you must pull them from the Tape player connector.
Pull your Tape player out, and unplug the connector that gives power to the Tape player. If you don't have the wire configuration here it is:
Orange/Black = 12 volts all the time (If you don't have Antitheft you need this for PIN 12).
Black/Green = Ground (use for PIN 5)
Blue/Black = 12 volt when ignition on (use for PIN 3)
White/Green = Voltage for Illumination from Dimmer(Use for PIN 4)
That is all you need. Please check the voltages on your own to verify that you have the same numbers. If you do this, you do it on your own risk and I have no responsibility for any damage you may cause to your car.
INSERT CONNECTOR PIC HERE
Details.
