drggntaco
im not even gonna say why...but im wondering how the odometer is driven on a 96 contour with the sport cluster...cable or electronic?!?
ok...my next question would be is the actual speedo electronic as well?? like if 1 works they both work type thing?? or could i disable the odometer and just have speedo??
i know if i say yes everyone is gonna rag on me about it....so uhhh....no...:shrug:
but ya, i had a camaro back in the day and it had a little switch installed so you could just turn on/off the speedometer/odometer, didnt know what the switch was for untill i kicked it with my foot while driving and cut the dash off... previous owner must have installed it, and i didnt know about it for almost a year after i had the car... but my tour has sickening low miles, and just wondering if this could be a possibility on one of these cars....or if it was possible to do?!?
Take it apart and find out. You won't get any more help from here.
realized this already...:nonono:
cant really tell you if yours has been modified, I can only tell you it is possible. As far as telling you how to do it, I am not going to, and I doubt you will find anyone else on here who will. It would be obvious if you took it apart if it was modified, but I doubt it was. If you try to modify it yourself I hope it breaks for you, the only time one should ever adjust their odometer is if they are swapping in a different cluster and are adjusting it to match their actual mileage.
That's the only time I did it, when I switched from KM to MPH. If you even try to move the odometer digits backwards it will scrap up the numbers and it's nearly impossible to put it back together so it looks like nothing has been tampered with it. I know I couldn't but then again I have a honest reason of doing it. What's your reason?
:nonono: to yourself .... what your trying to do I am pretty sure is illegal anyway ... what do you expect :shrug:
:help:
