KAOS_3.0
so...
I'm pretty determined to keep my EGR functioning.
what have any guys still running EGR done about heat shielding and that darned 5/8 coupling?
I've got all the mesh heat protection stuff from both egr pipes on it, but it still gets hot and smokes and it melted a hole in my evap that I had to rig up for now with duct tape. I'm also worried it's probably leaking at the 5/8 compression fitting, because it feels wiggly when you pull the uim off.
I'm thinking of going for two compression fittings, and a piece of 5/8 copper to give it a flex area so it wont wiggle loose when pulling the uim, sound smare? or does copper not stand up to 1500 degrees?
and what would you do to stop it from melting the earth in there? all that heat soak cant be good anyways, should I buy some header wrap or something? aluminum sheet metal shield? both?
thanks guys
thanks guys
