ok so while cruising on the highway my oil pressure as read at the remote oil filter sits right at the 65 psi that it should be from the factory. Now when I roll into the throttle then let off I see the oil pressure raise. While in boost the oil pressure doesn't change. Not sure if there is an issue or not ... any thoughts?
