Humboldtkill
- Joined
- Mar 20, 2008
- Messages
- 431
I was just checking into my rear end noise and i seen a sway bar bushing and the bracket mounted on the bushing i not bolted or hooked to anything? The bar itself has an inch or more movement,is this normal? I will post pics in a few im going back out now. How would i know if i have the 21mm or 19mm sway bar, when i bought the car i was told it was a 21 but i want to be sure. What wouls the size be in inches? I could measure it but dont know chit about mm. Thank you for your time reading this many ppl with many problems means alot of reading so any help is always appreciated.
It seems, and im no expert here but the bushings were ripped off the mounts repaired and ripped again? Its hard to believe those weak little brackets are expected to hold up under hard cornering? Am i alone in this?
Driver side
Pass side
Driver side
Pass side
